Unknown Action Handlers using a case sensitive lookup on ActionName
So I discovered today UnknownActionHandlers are used to handled things like XForms posts and presumably other specific non declared actions on controllers which looks rather neat.
However I set all my routes to be lowercase:
protected override void RegisterRoutes(RouteCollection routes)
    base.RegisterRoutes(routes);
    routes.LowercaseUrls = true;
This breaks things.
I realised that EPiServer.Web.Mvc.ActionControllerBase.HandleUnknownActions is doing a case senstive check on the unknown actions. Since actions are not normally handled case sensitively this seems like a bit of a bug.
I fixed it by overriding it in my page controller in this instance but not sure if anything else may be affected.
protected override void HandleUnknownAction(string actionName)
    foreach (var grouping in UnknownActionHandlers)
        if (!string.Equals(grouping.Key, actionName, StringComparison.CurrentCultureIgnoreCase))
            continue;
        foreach (var unknownActionHandler in grouping)
            var actionResult = unknownActionHandler.HandleAction(this);
            if (actionResult == null)
                continue;
            actionResult.ExecuteResult(ControllerContext);
            return;
    base.HandleUnknownAction(actionName);
#176922
Edited, Mar 29, 2017 20:15
