Bug: Episerver.MarketingAutomationIntegration visitor profile check crashes
We're using Episerver.MarketingAutomationIntegration with the Eloqua add-on and have discovered that when we try to filter visitors on float values in Eloqua with a criteria that is either "less than" or "more than" (or any variation of these types of checks) the page crashes.
To re-produce:
  1. Add a Marketing Automation Criteria profile and connect it to the Eloqua database
  2. Choose a column that stores float values in Eloqua
  3. Choose a condition that contains either "less" or "greater"
  4. Set the value to a number (if the add-on interprets the value as a string the page does not crash, but the "is match" check does not work either)
  5. Add the visitor group to a block
  6. Load a page where the block exists (and make sure your _elmai_trk cookie points to an Eloqua user that actually has a float value stored in the column chosen in step 2.)
  7. The page crashes
Br,
Gustav
#185994
Edited, Dec 08, 2017 10:07
