Discount is not Working Properly
I have updated the episerver
commerce core to 10.2.1
commerce also 10.2.1.
Episerver Framework 10.3.1
Now if I am working with discount the resulted discount is not coming properly.
Discount: Get Cheapest For Free
Buy at least X items from catalog entries, get the cheapest Y for free.
I gave value for
Buy at least...
  • X items
3
 From these entries
Men
Get cheapest Y for free
1
Promotion code
ABC0015
The discount is successfully applied but not visible any effect.
I have tried in Quick Silver where versions are
commerce core to 9.12.2
commerce also 9.24.1
Episerver Framework 9.12.2
There I can find the result is all right.
What to do I can’t understand.
My project architecture is the copy architecture of Episerver Commerce Starter Kit .
The code I copied from quick silver is :-
ICart cart = _Cart;
                    var couponCodes = cart.GetFirstForm().CouponCodes;
                    IPromotionEngine _promotionEngine = ServiceLocator.Current.GetInstance();
                    couponCodes.Clear();
                    couponCodes.Add(code);
                    var rewardDescriptions = cart.ApplyDiscounts(_promotionEngine, new PromotionEngineSettings());
                    var appliedCoupons = rewardDescriptions.Where(r => r.Status == FulfillmentStatus.Fulfilled && !string.IsNullOrEmpty(r.Promotion.Coupon.Code))
                                                           .Select(c => c.Promotion.Coupon.Code);
                    var couponApplied = appliedCoupons.Any(c => c.Equals(code, StringComparison.OrdinalIgnoreCase));
                    if (!couponApplied)
                        couponCodes.Remove(code);
#173978
Jan 16, 2017 9:27
"Not visible any effect"? what effect are you expecting to see that isn't there?
One thing off the top of my head is have you enabled VNext?
Described by Joel Yourstone at the end of this discussion:
http://world.episerver.com/Modules/Forum/Pages/Thread.aspx?id=150182
The setting says it is for workflows but it affects things even if you aren't running any workflows.
It is a nice little caveat for people trying to get the promotions running. :)
#174016
Jan 16, 2017 16:50
