Have you tried adding the route first in the route table? By switching line 3 and 4 in your first snippet.
There is another route that captures the request before your one (not a content route added by base.RegisterRoutes). You can however get your route before the other one by doing:
var route = routes.MapRoute(
"foo",
"foo.pdf",
new { controller = "Foo", action = "Index" }
routes.Remove(route);
routes.Insert(0, route);
Thanks Johan, I got an answer back from Epi support who said there's a bug but suggested that workaround. It works, although it messed up a few other routes so had to fix those as well.
I'm unable to route a static file to an MVC route when the file exists on disk, although it works fine if the file isn't there.
This is what I've done:
Overriding the RegisterRoutes in Global.asax
Added RouteConfig.cs
Added a handler in system.webServer/handlers
According to Jon Galloway is should work if you add the routes.RouteExistingFiles = true, but I still get an error. Any ideas on how to fix it?
