Hey Danie
I just provided what might be a solution over on the other thread: http://world.episerver.com/forum/developer-forum/EPiServer-Commerce/Thread-Container/2016/3/customize-tinymce/?pageIndex=1#reply
David
When trying to add a html button to the TinyMce editors in code, I get an exception in the "All properties" view. The same happens on the Alloy site (v9.6.1).
2016-03-08 08:47:40,967 [11] ERROR EPiServer.Global: 1.2.5 Unhandled exception in ASP.NETb__39(IAsyncResult asyncResult, ActionInvocation innerInvokeState)b__3d()b__3f()b__3f()b__32(IAsyncResult asyncResult)b__1c()b__1e(IAsyncResult asyncResult) > >> > > >
System.Collections.Generic.KeyNotFoundException: The given key was not present in the dictionary.
at System.Collections.Generic.Dictionary`2.get_Item(TKey key)
at EPiServer.Cms.Shell.UI.ObjectEditing.EditorDescriptors.XhtmlStringEditorDescriptor.ModifyMetadata(ExtendedMetadata metadata, IEnumerable`1 attributes)
at EPiServer.Shell.ObjectEditing.ExtensibleMetadataProvider.ApplyExtendersToMetadata(ExtendedMetadata metadata, IEnumerable`1 attributes, IEnumerable`1 metadataHandlers)
at EPiServer.Shell.ObjectEditing.ExtensibleMetadataProvider.GetMetadataForProperties(ExtendedMetadata parent, Object container, Type containerType, IMetadataProvider customProvider)
at EPiServer.Shell.ObjectEditing.ExtendedMetadata.get_Properties()
at EPiServer.Cms.Shell.UI.ObjectEditing.AllowedTypesMetadataExtender.ModifyMetadata(ExtendedMetadata metadata, IEnumerable`1 attributes)
at EPiServer.Shell.ObjectEditing.ExtensibleMetadataProvider.CreateMetadata(IEnumerable`1 attributes, Type containerType, Func`1 modelAccessor, Type modelType, String propertyName)
at System.Web.Mvc.AssociatedMetadataProvider.GetMetadataForType(Func`1 modelAccessor, Type modelType)
at EPiServer.Shell.UI.Rest.MetadataStore.Get(String id, String modelAccessor)
at lambda_method(Closure , ControllerBase , Object[] )
at System.Web.Mvc.ActionMethodDispatcher.Execute(ControllerBase controller, Object[] parameters)
at System.Web.Mvc.ReflectedActionDescriptor.Execute(ControllerContext controllerContext, IDictionary`2 parameters)
at System.Web.Mvc.ControllerActionInvoker.InvokeActionMethod(ControllerContext controllerContext, ActionDescriptor actionDescriptor, IDictionary`2 parameters)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.ActionInvocation.InvokeSynchronousActionMethod()
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult`2.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResultBase`1.End()
at System.Web.Mvc.Async.AsyncResultWrapper.End[TResult](IAsyncResult asyncResult, Object tag)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethod(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.
at System.Web.Mvc.Async.AsyncControllerActionInvoker.AsyncInvocationWithFilters.<>c__DisplayClass46.
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass33.
at System.Web.Mvc.Async.AsyncResultWrapper.WrappedAsyncResult`1.CallEndDelegate(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeActionMethodWithFilters(IAsyncResult asyncResult)
at System.Web.Mvc.Async.AsyncControllerActionInvoker.<>c__DisplayClass21.<>c__DisplayClass2b.
at System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult)
at EPiServer.Shell.Services.Rest.RestControllerBase.EndExecute(IAsyncResult asyncResult)
at EPiServer.Shell.Services.Rest.RestHttpHandler.EndProcessRequest(IAsyncResult result)
