I also got that exception when upgrading to 10.3 from CMS 10.2.
A work around is upgrading CMS UI package to 10.3.0.0.
CMS 10.3.0 had the wrong CMS UI dependency (10.2.0 instead of 10.3.0) and has now been updated.
http://nuget.episerver.com/en/OtherPages/Package/?packageId=EPiServer.CMS&packageVersion=10.3.0
My application uses CMS 9.12 hosted on cloud. I am trying to upgrade CMS to 10.3. I updated CMS as well as updated database by using UpdateDatabaseSchema=true.
When I am running my application it gives following error:
While loading .NET types from "EPiServer.Cms.Shell.UI" the following error(s) was reported:
- System.TypeLoadException: Method 'FormatUserMessageAsync' in type 'EPiServer.Cms.Shell.UI.Notifications.Internal.ProjectNotificationFormatter' from assembly 'EPiServer.Cms.Shell.UI, Version=10.2.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' does not have an implementation.
Exception Details: EPiServer.Framework.Initialization.InitializationException: While loading .NET types from "EPiServer.Cms.Shell.UI" the following error(s) was reported:
Source Error:
Source File: c:\Users\gmv51\AppData\Local\Temp\Temporary ASP.NET Files\root\51a1b133\2797a1ae\App_global.asax.0.cs Line: 0
Stack Trace:
[InitializationException: While loading .NET types from "EPiServer.Cms.Shell.UI" the following error(s) was reported: - System.TypeLoadException: Method 'FormatUserMessageAsync' in type 'EPiServer.Cms.Shell.UI.Notifications.Internal.ProjectNotificationFormatter' from assembly 'EPiServer.Cms.Shell.UI, Version=10.2.0.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7' does not have an implementation. ] EPiServer.Framework.Initialization.Internal.InitializationExceptionHelper.ThrowFriendlyTypeScannerException(IEnumerable`1 reflectionExceptions, IEnumerable`1 addonsWithErrors) +95 EPiServer.Framework.Initialization.InitializationModule.EngineExecute(HostType hostType, Action`1 engineAction) +682 EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType) +170 EPiServer.Global..ctor() +76 Vattenfall.CustWeb.UI.EPiServerApplication..ctor() +42 ASP.global_asax..ctor() in c:\Users\gmv51\AppData\Local\Temp\Temporary ASP.NET Files\root\51a1b133\2797a1ae\App_global.asax.0.cs:0 [TargetInvocationException: Exception has been thrown by the target of an invocation.] System.RuntimeTypeHandle.CreateInstance(RuntimeType type, Boolean publicOnly, Boolean noCheck, Boolean& canBeCached, RuntimeMethodHandleInternal& ctor, Boolean& bNeedSecurityCheck) +0 System.RuntimeType.CreateInstanceSlow(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +113 System.RuntimeType.CreateInstanceDefaultCtor(Boolean publicOnly, Boolean skipCheckThis, Boolean fillCache, StackCrawlMark& stackMark) +206 System.Activator.CreateInstance(Type type, Boolean nonPublic) +83 System.RuntimeType.CreateInstanceImpl(BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes, StackCrawlMark& stackMark) +1065 System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture, Object[] activationAttributes) +124 System.Activator.CreateInstance(Type type, BindingFlags bindingAttr, Binder binder, Object[] args, CultureInfo culture) +20 System.Web.HttpRuntime.CreateNonPublicInstance(Type type, Object[] args) +60 System.Web.HttpApplicationFactory.GetSpecialApplicationInstance(IntPtr appContext, HttpContext context) +276 System.Web.Hosting.PipelineRuntime.InitializeApplication(IntPtr appContext) +296 [HttpException (0x80004005): Exception has been thrown by the target of an invocation.] System.Web.HttpRuntime.FirstRequestInit(HttpContext context) +9947444 System.Web.HttpRuntime.EnsureFirstRequestInit(HttpContext context) +101 System.Web.HttpRuntime.ProcessRequestNotificationPrivate(IIS7WorkerRequest wr, HttpContext context) +261Help me out from this.
Thanks & Regards,
Sanket Mahimkar
