Bug in EPiServer.Forms.Core.Data.GetPostedFiles when uploadig multiple files
I noticed that you have prepared for multiple file uploads with the forms element, thres however a bug in EPiServer.Forms.Core.Data.GetPostedFiles
The input "rawData" looks like this with one and two uploaded files
1 file: rawData = "fileUrl#@fileName"
2 files: rawData = "fileUrl#@fileName|fileUrl2#@fileName2"
The GetPostedFiles-method works with 1 file but not with two.
Original code:
private IDictionary GetPostedFiles(string rawData)
      Dictionary dictionary = new Dictionary();
      string[] strArray = rawData.SplitBySeparator("|");
      if (((IEnumerable) strArray).Count() == 0)
        return (IDictionary) dictionary;
      string empty1 = string.Empty;
      string empty2 = string.Empty;
      string str1 = "#@";
      foreach (string str2 in strArray)
        int length = str2.IndexOf(str1);
        string str3 = rawData.Substring(length + str1.Length);
        string key = rawData.Substring(0, length);
        dictionary.Add(key, str3);
the rows:
should be
string str3 = str2.Substring(length + str1.Length);
string key = str2.Substring(0, length);
#172014
Edited, Nov 23, 2016 14:26
