Error Loading Admin CMS
We are having some difficulty loading the admin section of the CMS. When we navigate to the Admin section we get the following error.
Unable to find a module by assembly 'EPiServer.GoogleAnalytics, Version=1.2.1.1, Culture=neutral, PublicKeyToken=null'
However i can confirm that the DLL is in the modulesbin folder, any ideas?
Regards,
Josh Robertson
#122211
May 28, 2015 10:52
which version of EPiServer? did you upgrade recently? is .dll in modulesbin/ of correct version (1.2.1.1)?
#122216
May 28, 2015 13:05
Hello Josh, what version of EPiServer are you running and what mechanism have you used to install add-ons? If running EPiServer 8 and haven't your add-ons then there is Powershell command that can help you migrate called: convert-epiaddons. This should move everything into all the right places for you.
See the following post for more information: http://world.episerver.com/blogs/linus-ekstrom/dates/2015/2/a-first-introduction-to-the-upcoming-episerver-cms-8/
David
#122217
May 28, 2015 13:05
Hi Valdis,
Its Episerver Version 7.0.586.1, and yes i can confirm that the Google Anyalitics version is 1.2.1.1, the site hasnt ever been upgraded.
Regards,
Josh Robertson
#122364
Jun 01, 2015 13:01
