This looks like a bug. When I have a simple LinkItemCollection property in my page or block content item, I cannot remove more than one link at a time in IE10. It works fine in Firefox 31, however. I have tested such a property in both a block and a page content type. My block property looks like this:
When in edit mode for the content item using IE 10, if I remove more than one item in the list using "Remove" in the drop-down menu for each item, they are removed as expected while still in edit mode, but as soon as I publish the change, all links except the first to be removed re-appear. Can anyone reproduce this and if so confirm that it is indeed a bug?
