Cannot have single or double quotes in property descriptions or default values [7.5]
I have noticed that if you have a single or double quote in a property name or default value in EPiServer 7.5, the text past and including the first quote is cut off.
e.g. I add a description to a property that says
The heading text at the top of the page, e.g. 'Welcome'
It would display the following when hovering over (viewing description)
Because it cuts after the first ' or \".
This may apply to other things such as property names, I haven't tested extensively to see what is affected.
#82090
Mar 05, 2014 12:41
You can solve this by escaping the quote with a backslash
Description = "The heading text at the top of the page, e.g. \"Welcome\""
#82144
Mar 05, 2014 21:55
You can also use HTML inside the names and descriptions.
#82146
Mar 05, 2014 23:26
