Epi Server 7 (Dev machine)
Hey People
I am getting the following error and I have no idea from where. Any ideas? What is the IMetaDataResolver? and why am I missing it?
ERROR 2013-08-28 11:00:45 EPiServer.Shell.ShellInitialization: System.AggregateException: One or more errors occurred. ---> StructureMap.StructureMapException: StructureMap Exception Code: 202
No Default Instance defined for PluginFamily EPiServer.Cms.Shell.UI.Rest.IMetaDataResolver, EPiServer.Cms.Shell.UI, Version=1.0.431.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7
at StructureMap.BuildSession.<.ctor>b__0(Type t) in c:\BuildAgent\work\767273992e840853\src\StructureMap\BuildSession.cs:line 33
at StructureMap.Util.Cache`2.get_Item(KEY key) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Util\Cache.cs:line 83
at StructureMap.BuildSession.CreateInstance(Type pluginType) in c:\BuildAgent\work\767273992e840853\src\StructureMap\BuildSession.cs:line 215
at StructureMap.Pipeline.Instance.createRawObject(Type pluginType, BuildSession session) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Pipeline\Instance.cs:line 109
at StructureMap.Pipeline.Instance.Build(Type pluginType, BuildSession session) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Pipeline\Instance.cs:line 73
at StructureMap.Pipeline.ConstructorInstance.Get[T](String propertyName, BuildSession session) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Pipeline\ConstructorInstance.cs:line 80
at lambda_method(Closure , IArguments )
at StructureMap.Construction.BuilderCompiler.FuncCompiler`1.<>c__DisplayClass2.<CreateBuilder>b__0(IArguments args) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Construction\BuilderCompiler.cs:line 56
at StructureMap.Construction.InstanceBuilder.BuildInstance(IArguments args) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Construction\InstanceBuilder.cs:line 34
at StructureMap.Pipeline.ConstructorInstance.Build(Type pluginType, BuildSession session, IInstanceBuilder builder) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Pipeline\ConstructorInstance.cs:line 247
at StructureMap.Pipeline.ObjectBuilder.Resolve(Type pluginType, Instance instance, BuildSession session) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Pipeline\ObjectBuilder.cs:line 30
at StructureMap.BuildSession.CreateInstance(Type pluginType, Instance instance) in c:\BuildAgent\work\767273992e840853\src\StructureMap\BuildSession.cs:line 176
at StructureMap.BuildSession.CreateInstanceArray(Type pluginType, Instance[] instances) in c:\BuildAgent\work\767273992e840853\src\StructureMap\BuildSession.cs:line 202
at StructureMap.Container.GetAllInstances(Type pluginType) in c:\BuildAgent\work\767273992e840853\src\StructureMap\Container.cs:line 311
at EPiServer.ServiceLocation.StructureMapServiceLocator.<DoGetAllInstances>d__0.MoveNext()
at EPiServer.ServiceLocation.ServiceLocatorImplBase.<GetAllInstances>d__0`1.MoveNext()
at System.Linq.Enumerable.WhereSelectEnumerableIterator`2.MoveNext()
at EPiServer.Shell.Modules.ModuleInitializer.RegisterRestStores(IEnumerable`1 modules, IEnumerable`1 restStoreTypes)
at System.Threading.Tasks.Task.Execute()
at System.Threading.Tasks.Task.Wait(Int32 millisecondsTimeout, CancellationToken cancellationToken)
at EPiServer.Shell.ShellInitialization.WaitForInitializeModules()
---> (Inner Exception #0) StructureMap.StructureMapException: StructureMap Exception Code: 202
at System.Threading.Tasks.Task.Execute()<---
ERROR 2013-08-28 11:00:45 EPiServer.Global: 1.2.5 Unhandled exception in ASP.NET
System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> StructureMap.StructureMapException: StructureMap Exception Code: 202
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at EPiServer.Framework.Initialization.InitializationEngine.OnInitComplete()
at EPiServer.Framework.Initialization.InitializationEngine.Initialize(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.Initialize(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.FrameworkInitialization(HostType hostType)
at EPiServer.Framework.Initialization.InitializationModule.Application_BeginRequest(Object sender, EventArgs e)
at System.Web.HttpApplication.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
#74459
Aug 28, 2013 11:04
When are you registering the StructureMap IoC container? If you´re doing it in global.asax´s Application_Start method, try instead and use an IInitializableModule instead.
Frederik
#76737
Oct 31, 2013 19:59
