Here is a proposed BUGFIX/SOLUTION: Add the following two lines in EPiServer.UI.Edit.ImageEditor.Core.FileIO's SaveFileAs()-method (at line 16 in my previous post):
var originalUnifiedFile = HostingEnvironment.VirtualPathProvider.GetFile(originalVirtualPath) as UnifiedFile;
UnifiedFile.CopySummary(originalUnifiedFile, unifiedFile);
Looks like a simple fix, is it possible to get this fixed in the next version? :)
FileSummary.config:
When users upload images, they enter photographer under Author in EPiServer's filemanager->Edit fileinfo. When I copy->paste a file in EPiServers filemanager, the fileinfo is copied as well. But when I insert an image into an article, open EPiServers ImageEditor, resize the image, and save a copy in the pagefolder, the fileinfo is not copied. Is this a bug/missing functionallity in EPiServers ImageEditor? I think the file is saved in EPiServer.UI.Edit.ImageEditor.Core.FileIO.SaveFileAs():
Do you have a suggestion for a workaround?
EPiServer 6 R2 (6.1.379.0)
-Thomas
