Emptying trash can in Episerver-project ; Object reference not set to an instance of an object.
I get the following error when I empty the trash can in an Episerver-project deployed at the server of a customer:"Object reference not set to an instance of an object."
How can I find which object reference that is causing this error?
Thanks in advance!
Anders Branderud
#61470
Sep 20, 2012 12:15
I tested to remove the object in the trash bin one by one, and for on of the objects I got this error:
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
   EPiServer.DataAccess.PageLoadDB.LoadPageInternal(PageReference pageLink, Int32 languageBranchId, IDataReader reader) +1195
   EPiServer.DataAccess.<>c__DisplayClass1.<LoadPage>b__0() +304
   EPiServer.DataAccess.<>c__DisplayClass1`1.<Execute>b__0() +202
   EPiServer.DataAccess.DatabaseFactory.Execute(Action`1 method) +73
   EPiServer.Core.<>c__DisplayClass4.<GetPageInternal>b__3() +148
   EPiServer.Core.OptimisticCache`1.Read(String cacheKey, ReadAndCacheObject`1 readAndCacheObject) +1249
   EPiServer.Core.PageProviderBase.GetPageInternal(PageReference pageLink, ILanguageSelector selector) +830
   EPiServer.DataFactory.GetPage(PageReference pageLink, ILanguageSelector selector) +443
   EPiServer.ChangeLog.ChangeLogTracker.PreparePageDeleteLog(PageEventArgs args) +131
   EPiServer.PageEventHandler.Invoke(Object sender, PageEventArgs e) +0
   EPiServer.Core.PageStoreBase.RaisePageEvent(Object key, IList`1 pageLinks, PageEventArgs eventArgs) +221
   EPiServer.DataFactory.Delete(PageReference pageLink, Boolean forceDelete, AccessLevel access) +480
   EPiServer.UI.Edit.DeletePage.Delete_Click(Object sender, EventArgs e) +335
   EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +254
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +3691
#61472
Sep 20, 2012 12:30
I solved the problem by executing a sql query deleting the page:
exec  editDeletePage 3807
#61473
Sep 20, 2012 12:50
