Google Analytics compile error
Testing to create a GadgetMetric in my solution using the guidelines but get compile errors (EPiServer CMS 6 R2, with latest GA plugin)
'System.ComponentModel.Composition.ExportAttribute' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.ComponentModel.Composition, Version=2009.22.10.0, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
But System.CompinentModel.Composition is already referenced, my web.config:
<dependentAssembly>
<assemblyIdentityname="System.ComponentModel.Composition"publicKeyToken="8fe83dea738b45b7"culture="neutral"/>
<bindingRedirectoldVersion="1.0.0.0-2009.22.10.0"newVersion="2009.22.10.0"/>
</dependentAssembly>
Error 2 'EPiServer.GoogleAnalytics.Analytics.GadgetMetricAttribute' is not an attribute class
This is my simple code, added the class to root:
using System;
using System.Linq;
using System.Web;
using EPiServer.GoogleAnalytics;
using EPiServer.GoogleAnalytics.Analytics;
using EPiServer.GoogleAnalytics.Analytics.Models;
namespace EPiServer.GoogleAnalytics.Analytics
    [GadgetMetric]
    public class TestGa : ListMetricBase
        public override string Metric
            get { return "ga:pageviews"; }
        public override string Dimension
            get
                return "ga:pageTitle";
What is missing?
#64016
Dec 07, 2012 10:34
Something got wrong when pasting, can't edit, namespace in class should of course be the name of my solution
#64017
Dec 07, 2012 10:40
Step 6. of this article. It should solve our problem:
http://world.episerver.com/Articles/Items/EPiServer-CMS-60-now-supporting-ASPNET-40/
#64117
Dec 11, 2012 10:12
