Compare Differences crash on CDATA in Javascript
Running CMS 6 R1... I get this error when trying to compare differences between versions:
System.ArgumentException
Cannot have ']]>' inside an XML CDATA block.
Stacktrace:
   at System.Xml.XmlTextWriter.WriteCData(String text)
   at System.Xml.XmlElement.WriteContentTo(XmlWriter w)
   at System.Xml.XmlElement.WriteTo(XmlWriter w)
   at System.Xml.XmlNode.get_OuterXml()
   at EPiServer.UI.Edit.PageCompare.Core.Providers.PageCompareAlgorithm.RecursiveNodeCompare(XmlNode firstNode, XmlNode secondNode, StringBuilder final)
   at EPiServer.UI.Edit.PageCompare.Core.Providers.PageCompareAlgorithm.GetDiffOfHtml(String html1, String html2)
   at EPiServer.UI.Edit.PageCompare.VisualPageCompare.OnLoad(EventArgs e)
   at System.Web.UI.Control.LoadRecursive()
   at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
I guess the easy way around it is to change the javascripts... But is there maybe a fix available?
#52793
Aug 15, 2011 15:07
Here's the banner ad code that contains the CDATA-syntax...
<script type="text/javascript"><!--//--><![CDATA[//><!--
	if (window.adgroupid == undefined) {
		window.adgroupid = Math.round(Math.random() * 1000);
	document.write('<scr'+'ipt type="text/javascript" sr'+'c="http://adsby.webtraffic.se/addyn/3.0/733/2364582/0/321/ADTECH;cookie=info;loc=100;target=_blank;grp='+window.adgroupid+';misc='+new Date().getTime()+'"></'+'scri'+'pt>');
</script>
#52794
Aug 15, 2011 15:10
It is a known bug in CMS 6 R1.
Bug #43920.
#52802
Edited, Aug 15, 2011 21:21
Ah ok, thanks Toni. I altered the CDATA comment syntax and got the compare page to load by the way... However it messes up STYLE-elements so @import-statements such as this fails. Is that also a known bug?
EDIT: To clarify this is the resulting code after comparing... There is no CDATA in the original HTML source.
<style media="all" type="text/css"><![CDATA[
	@import '/mycsspath.css';
]]></style>
#52806
Edited, Aug 16, 2011 9:27
STYLE-elements with @import-statements seems to be working ok now after upgrading to CMS 6 R2.
#54440
Oct 14, 2011 16:13
