context menu affects comparing versions
Hi, I raised this in developer to developer forum but we have since discovered the problem, please see below for inital question and the issue we found - posted by me
Hi I am using CMS 6 and at the moment when we click on compare the only option that displays anything is the property changes.  Both of the other two options dont display anything.  has anyone else had this problem? Anyone know of any solutions?
posted by a colleague
After further investigation we (I work with Gwen) have worked out that this is caused by turning off the context menu in plug-in manager.
We want to turn off the context menu as a shortcut to disable quick edit.
Any ideas?
#43728
Sep 22, 2010 13:09
