Copy page error in CMS5 R2 SP2
When i make a copy of a page tree in the editor with copy and paste, i get the following error. (see below)
Does anybody know a solution?
[Importing page 25215_41644] Can't copy page, because: Can't map a page folder to a file that belongs to a page with PageGuid = '089c515a-d954-4dd7-b9af-c71395f13fdd'
Exception Details: EPiServer.Core.EPiServerException: [Importing page 25215_41644] Can't copy page, because: Can't map a page folder to a file that belongs to a page with PageGuid = '089c515a-d954-4dd7-b9af-c71395f13fdd'
Source Error:
Stack Trace:
[EPiServerException: [Importing page 25215_41644] Can't copy page, because: Can't map a page folder to a file that belongs to a page with PageGuid = '089c515a-d954-4dd7-b9af-c71395f13fdd']
   EPiServer.LocalPageProvider.Copy(PageReference pageLink, PageReference destinationLink, Boolean publishOnDestination, Boolean allowThreading) +530
   EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, AccessLevel requiredSourceAccess, AccessLevel requiredDestinationAccess, Boolean publishOnDestination, Boolean allowThreading) +323
   EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, Boolean allowThreading) +132
   EPiServer.UI.Edit.CommandActions.PasteCommandTool_Click(Object sender, EventArgs e) +958
   EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +103
   EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +179
   System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +29
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2981
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
#38647
Apr 16, 2010 0:02
Did you manage to find a solution to this problem? We're seeing a similar issue occuring but during mirroring.
Justin
#41462
Jul 07, 2010 17:49
I experienced this using mirroring, and the problem was that one page had a reference to a file in a Page File-folder belonging to another page.
#41463
Jul 07, 2010 21:25
