1. select web.config files.
2. select "Next".
3. On the messagebox that is displayed choose "No" (do not migrate database).
4. Now you can press the "Previous" button (it should be Enabled="False").
5. An error appears and the application terminates.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ApplicationException: Load can only be called when the State is MigrationState.NotValidated
at EPiServer.Migration.MigrationEngine.Load(String episerver4ConfigPath, String episerver5ConfigPath, Boolean newMigration)
at MigrationTool.WizardControls.Setup.OnNext()
at MigrationTool.MainForm.nextButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.3082 (QFE.050727-3000)
CodeBase: file:///c:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
MigrationTool
Assembly Version: 1.1.0.38
Win32 Version: 1.1.0.38
CodeBase: file:///C:/Program%20Files/EPiServer/MigrationTool/MigrationTool.exe
Win32 Version: 2.0.50727.3053 (netfxsp.050727-3000)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
EPiServer.MigrationEngine
CodeBase: file:///C:/Program%20Files/EPiServer/MigrationTool/EPiServer.MigrationEngine.DLL
System.Workflow.Runtime
Assembly Version: 3.0.0.0
Win32 Version: 3.0.4203.2152 (SP.030729-0100)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Workflow.Runtime/3.0.0.0__31bf3856ad364e35/System.Workflow.Runtime.dll
System.Workflow.ComponentModel
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Workflow.ComponentModel/3.0.0.0__31bf3856ad364e35/System.Workflow.ComponentModel.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
System.Data
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Data/2.0.0.0__b77a5c561934e089/System.Data.dll
System.Transactions
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.Transactions/2.0.0.0__b77a5c561934e089/System.Transactions.dll
System.EnterpriseServices
CodeBase: file:///C:/WINDOWS/assembly/GAC_32/System.EnterpriseServices/2.0.0.0__b03f5f7f11d50a3a/System.EnterpriseServices.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
