XForms Property NullReference in Edit mode
I'm having trouble with adding XForms Property as a Dynamic Property on one of our sites running EPiServer CMS 5 R2
I can add it as usual in admin mode but then i go to Edit mode and edit Dynamic Properties for the site i get a NullReference error.
   EPiServer.Web.WebControls.InputXForm.CreateChildControls() +541
   System.Web.UI.Control.EnsureChildControls() +87
   System.Web.UI.Control.PreRenderRecursiveInternal() +44
   System.Web.UI.Control.PreRenderRecursiveInternal() +171
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +842
So it looks like it can't render the XForm property control, but if I add the property on a page template it renders and works like it should. Any thoughts on what the problem might be?
#30047
May 28, 2009 10:52
I have also this problem. My stack trace is as following:
Objektreferensen har inte angetts till en instans av ett objekt.
Exception Details: System.NullReferenceException: Objektreferensen har inte angetts till en instans av ett objekt.
Source Error:
Stack Trace:
[NullReferenceException: Objektreferensen har inte angetts till en instans av ett objekt.]
#42814
Sep 02, 2010 9:58
Did anyone solve this problem? I'm now experiencing the exact same.
#64162
Dec 11, 2012 17:09
