Failed to map the path '/'.
I've got the following problem with EPiServer. I am developing with visual studio in Admin mode, but still I get this error message does any one know the reason?
Here is the stack trace if it gives any clues?
/Niklas
Exception Details: System.InvalidOperationException: Failed to map the path '/'.
[InvalidOperationException: Failed to map the path '/'.]
   System.Web.Configuration.ProcessHostMapPath.MapPathCaching(String siteID, VirtualPath path) +719
   System.Web.Configuration.ProcessHostMapPath.GetPathConfigFilenameWorker(String siteID, VirtualPath path, String& directory, String& baseName) +19
   System.Web.Configuration.ProcessHostMapPath.System.Web.Configuration.IConfigMapPath.GetPathConfigFilename(String siteID, String path, String& directory, String& baseName) +37
   System.Web.Configuration.HostingPreferredMapPath.GetPathConfigFilename(String siteID, String path, String& directory, String& baseName) +75
   System.Web.Configuration.WebConfigurationHost.GetStreamName(String configPath) +8838550
   System.Configuration.Internal.DelegatingConfigHost.GetStreamName(String configPath) +13
   System.Configuration.BaseConfigurationRecord.InitConfigFromFile() +154
[ConfigurationErrorsException: An error occurred loading a configuration file: Failed to map the path '/'.]
   System.Configuration.ConfigurationSchemaErrors.ThrowIfErrors(Boolean ignoreLocal) +651044
   System.Configuration.BaseConfigurationRecord.ThrowIfParseErrors(ConfigurationSchemaErrors schemaErrors) +31
   System.Configuration.Configuration..ctor(String locationSubPath, Type typeConfigHost, Object[] hostInitConfigurationParams) +356
   System.Configuration.Internal.InternalConfigConfigurationFactory.System.Configuration.Internal.IInternalConfigConfigurationFactory.Create(Type typeConfigHost, Object[] hostInitConfigurationParams) +29
   System.Web.Configuration.WebConfigurationHost.OpenConfiguration(WebLevel webLevel, ConfigurationFileMap fileMap, VirtualPath path, String site, String locationSubPath, String server, String userName, String password, IntPtr tokenHandle) +775
   System.Web.Configuration.WebConfigurationManager.OpenWebConfigurationImpl(WebLevel webLevel, ConfigurationFileMap fileMap, String path, String site, String locationSubPath, String server, String userName, String password, IntPtr userToken) +84
   System.Web.Configuration.WebConfigurationManager.OpenWebConfiguration(String path) +36
   EPiServer.Configuration.EPiServerSection.GetConfigurationFromFile() +28
   EPiServer.Configuration.EPiServerSection.get_CurrentConfiguration() +38
   EPiServer.Configuration.Settings.InitializeAllSettings() +22
   EPiServer.Configuration.Settings.MapHostToSettings(String hostName, Boolean fallback) +52
   EPiServer.Configuration.Settings.MapUrlToSettings(Uri url) +264
   EPiServer.Configuration.Settings.get_Instance() +160
   EPiServer.Web.InitializationModule.<StaticInitialization>b__0() +22
   EPiServer.Web.InitializeEngine.Initialize() +345
   EPiServer.Web.InitializationModule.StaticInitialization() +1485
   EPiServer.Web.InitializationModule.Application_BeginRequest(Object sender, EventArgs e) +414
   System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Hello!
#29985
May 26, 2009 10:30
Not sure, but I'd say something in your web.config file is broken.
#30039
May 27, 2009 20:26
Thanks for the answer!
 I installed EPiServer again and now everything works perfectly.
 Best regards
/Niklas
#30103
Jun 02, 2009 10:52
