A tip is to look at the thread information in your EPiserver log file when your root logger level is set to ALL. Then look at all messages for a certain thread that causes the error, and may be you can figure out what's wrong. I have written in my notes how to set the logging level in EPiServer http://epiwiki.se/configuration/logging
On my production server I use log4net to log errors and so on. About four times a minute(!) I get this entry in the log:
2009-04-29 13:13:03,105 ERROR [1] EPiServer.Global.Global_Error - 1.2.5 Unhandled exception in ASP.NET
I use the following log4net conversion pattern:
%date %level [%thread] %type.%method - %message%n%n%exception%n------------------%n%n
In the SDK I found the documention of the Global class and it seems the log entry is being made in the Global_Error method when it fails to get Server.GetLastError();
Exception e;
try
//Get the previous exception
e = Server.GetLastError();
catch
return;
_log.Error("1.2.5 Unhandled exception in ASP.NET", e);
There are no entries in the event log, so no help there finding out what causes the error.
Does anyone know what I can do to catch this? I get alooot of log email now. ;)
