Easiest solution, if you don't use it, is to just remove the file XmlPageProvider.dll from your bin folder.
The XmlPageProvider is just a sample implementation of a custom page provider, and not used internally by EPiServer CMS.
Regards
Per Gunsarfs
EPiServer CMS development team
Upgrade process went pretty smoothly but now I get this error when I try to go to the admin. Can anyone help?:
Failed to load some types from "XmlPageProvider": Could not load type 'EPiServer.Security.ISecurityDescriptor' from assembly 'EPiServer.BaseLibrary, Version=5.1.422.267, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'. Could not load type 'EPiServer.Core.PageProviderBase' from assembly 'EPiServer, Version=5.1.422.267, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
Exception Details: EPiServer.PlugIn.PlugInException: Failed to load some types from "XmlPageProvider": Could not load type 'EPiServer.Security.ISecurityDescriptor' from assembly 'EPiServer.BaseLibrary, Version=5.1.422.267, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'. Could not load type 'EPiServer.Core.PageProviderBase' from assembly 'EPiServer, Version=5.1.422.267, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
Source Error:
Stack Trace:
[PlugInException: Failed to load some types from "XmlPageProvider": Could not load type 'EPiServer.Security.ISecurityDescriptor' from assembly 'EPiServer.BaseLibrary, Version=5.1.422.267, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'. Could not load type 'EPiServer.Core.PageProviderBase' from assembly 'EPiServer, Version=5.1.422.267, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'. ]
EPiServer.PlugIn.AssemblyTypeInfo.GetTypes() +299
EPiServer.PlugIn.AssemblyTypeInfo.ScanAssembly() +164
EPiServer.PlugIn.PlugInLocator.get_Assemblies() +419
EPiServer.PlugIn.PlugInLocator.FindPlugInAttributes() +68
EPiServer.PlugIn.PlugInRuntime.Start() +11
EPiServer.Global.StaticInitialization() +71
EPiServer.Global.Global_BeginRequest(Object sender, EventArgs e) +125
System.Web.SyncEventExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +68
System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +75
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
