Hi Kristoffer,
Version 99 is the version of 4.62 and 100 is for 4.62B. Perhaps the database script didn't run through as they should have. What you can do is to create a offline package with the upgrade you did and open that in a compresser program (ex. winrar) and extract the database scripts that are run and rerun it on the database.
99 is 4.62.0
100 is 4.62B.
check the upgrade log file for eventuall errors/problems and/or try to run the upgrade script again. The sql upgrade scripts are downloaded to the server in the episerver folder (along with all other epifiles).
I received this message after upgrading to 4.62.0.533. What went wrong and what can be done about it?
The upgrade was done as preparation for migration to EPiServer 5.
