We are having a problem with the built-in copy/paste functionality in EPiServer 4.62.0.533. When right-clicking on a page and selecting "Copy" and then right-clicking somewhere else in the page tree and selecting "Paste", an error is given (see below)
Any ideas on what's wrong in this case?
Regards.
Emil
Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Stack Trace:
development.Global.CheckPropertiesForFormatting(PageEventArgs e) +31
development.Global.EPDataFactory_CreatingPage(Object sender, PageEventArgs e) +8
EPiServer.DataFactory.ᐁ(PageEventArgs , Object ) +67
EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, AccessLevel requiredSourceAccess, AccessLevel requiredDestinationAccess, Boolean publishOnDestination) +165
EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink) +143
EPiServer.Edit.CommandActionBase.PasteCommandTool_Click(Object sender, ImageClickEventArgs e) +1176
EPiServer.SystemControls.CommandTool.System.Web.UI.IPostBackEventHandler.RaisePostBackEvent(String param) +49
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +11
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +33
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1746
