Suddenly we cannot unfold a certain node in the epitree. In our log file I can see the following message. Seems like some value is wrong in one of the pages, but I can't figure out which one. What value might cause this problem?
Using epi 4.61.3
Error in: http://www.bilia.se/secure/editor/EditTree.aspx?id=56792
Referrer: http://www.bilia.se/secure/editor/QuickSearch.aspx?mode=&id=
Error Message: Page "56797" has invalid data, cannot find either master language branch or loaded version
Stack Trace:
at áš.á()
at áš.InitializeData(ApplicationConfiguration config)
at EPiServer.DataAccess.PageListDB.LoadList(PageReference pageLink)
at EPiServer.DataFactory.áƒ(PageReference )
at EPiServer.DataFactory.á(PageReference )
at EPiServer.DataFactory.GetChildren(PageReference pageLink, ILanguageSelector selector, AccessLevel access)
at EPiServer.WebControls.ExplorerTree.GetChildren(PageReference pageLink)
at EPiServer.PageTreeLoader.PreloadHasChildren(TreeState state, PageData page)
at EPiServer.PageTreeLoader.á(TreeState , PageReference , Boolean , Int32 )
at EPiServer.PageTreeLoader.GetPageTree(PageReference parent, PageReference[] openPages, IPageSource pageSource, Int32 nrOfLevels)
at EPiServer.WebControls.PageTreeData.PopulatePages(PageDataCollection pages)
at EPiServer.WebControls.PageControlBase.á()
at EPiServer.WebControls.PageControlBase.GetPages()
at EPiServer.WebControls.ExplorerTree.Render(HtmlTextWriter output)
at System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter)
at System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter)
at System.Web.UI.Control.RenderControl(HtmlTextWriter writer)
at System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children)
at System.Web.UI.Control.RenderChildren(HtmlTextWriter writer)
at System.Web.UI.WebControls.Label.RenderContents(HtmlTextWriter writer)
at System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer)
at System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output)
at System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer)
at ASP.secure_editor_edittree_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in d:\WebApplications\Bilia\secure\editor\EditTree.aspx:line 146
at System.Web.UI.Page.Render(HtmlTextWriter writer)
at System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint)
