Do you have 500 application error for the files in you app_themes folder? if you have that you could turn on the log for episerver. I had the same problem and found that I had misspelled <staticFile expirationTime="1.0:0:0" cacheControl="private" /> in our web.config. The site worked like before but edit and admin did not.
Have a look in firebug and if you have 500-error for the files turn on the log. I got this error messege:
System.Configuration.ConfigurationErrorsException: Unrecognized attribute 'cachecontrol'. Note that attribute names are case-sensitive. (C:\WebSite\....\web.config line 231)
/Eric
Im working on several EPiServer projects, and the latest of them i created from scratch using VS2008.
On this particular project, when i go to Edit Mode none of the images or styles from App_Themes folder is showing. This is also causing the Editor to not load with a javascript error.
On the other projects this is not a problem.
Anyone experienced this?
