Upgrading sp1 to sp2
We are using the IIS structure. Website.Inside website we are having the virutual directory
For ex we are having website called Website inside Website we are having website1,website2,website3.
When we upgrading a SP2 for a website3 ,we are not able to open the other website1 and website2 which is running in SP1 its giving following  error
"EPiServer 5.1.422.122 can only be used with database version 5101, current version is 5102. Make sure both database and assemblies are upgraded correctly"
#23097
Aug 27, 2008 6:48
Did you use the EPiServer Manager to install the upgrade?
#23100
Aug 27, 2008 9:02
I am upgrading thro the episerver manager only and we are using different episerver databases for every site .
Website1 ->episerver1 database
Website2 ->episerver2 database
Website3 ->episerver3 database
When we are upgrading the website3 with with episerver3 database sp2 we are getting the error
#23122
Aug 27, 2008 15:37
hi,
Could you explain "Website.Inside website " ?
Exactly how is the structure of EPiServer sites in the IIS?
It seems that website1 and 2 is pointing to the episerver3 database. So the current solution would be to also upgrade website1 and 2.
#23124
Aug 27, 2008 17:15
 we are having a IIS website inside the website we are having different virutual directories like Website1(name of virtual directory) ,website2 (name of virtual directory) ,website3 (name of virtual directory)
When i am upgrading the website3 (name of virtual directory)  with SP2 its giving the error in Website1(name of virtual directory) ,website2 (name of virtual directory) which is running in SP1
Website1(name of virtual directory) ->episerver1 database(Running in SP1)
Website2(name of virtual directory) ->episerver2 database(Running in SP1)
Website3(name of virtual directory) ->episerver3 database(Running in SP2)
Website1(name of virtual directory) ,Website2(name of virtual directory) and Website3(name of virtual directory)  are pointing to different episerverdatabases
#23148
Aug 28, 2008 9:58
