Problem attaching event
Hi, trying to attach an event in my global.asax
DataFactory.Instance.LoadedDefaultPageData += new PageEventHandler(Instance_LoadedDefaultPageData);
Works fine och test-server and live, but not on my computer (Running vista business sp1).
Error msg:
Request is not available in this context
Exception Details: System.Web.HttpException: Request is not available in this context
Source Error:
Line 23:         protected void Application_Start(Object sender, EventArgs e)
Line 24: {
Line 25: DataFactory.Instance.LoadedDefaultPageData += new PageEventHandler(Instance_LoadedDefaultPageData);
Line 26: }
Line 27:
#20742
Jun 10, 2008 14:45
Yeah, my collegues, who are developing this site, ran into that problem just the other day. This is due to, as I understood it, changes in the IIS. Instead of attaching to the event in Application_Start they had to run their code as a http module.
I'll see if I can get you some code later today.
#20750
Jun 11, 2008 1:32
Here's some sample code. Hope it helps.
public class EventHandler : IHttpModule
private static bool _isInited = false;
private static string locker = "1";
public void Init(HttpApplication context)
lock (locker)
if (!_isInited)
EPiServer.DataFactory.Instance.CreatingPage += new PageEventHandler(Instance_CreatingPage);
_isInited = true;
#20757
Jun 11, 2008 11:23
