Migration Tool RC1
Not really sure I'm supposed to write any q's about the migration tool here... well here we go...
I'm getting this nasty error message and I have no clue where to begin searching. My question is if there is another way to get more detailed error messages from the tool or perhaps go debugging it Foot in mouth
Regards, Andreas Ek, Internetfabriken.
[2008-05-26 20:59:52][Information] Migration Started
[2008-05-26 20:59:52][Information] Migration Started, current version of migration tool: 1.0.0.165
[2008-05-26 20:59:52][Information] Migrating Object Store...
[2008-05-26 20:59:53][Information] 0,24 % completed, 1(415)
[2008-05-26 20:59:54][Error] An error occurred migrating data in Object Store. The exception was:
System.TypeLoadException: Could not load type 'EPiServer.FileSystem.Handler.VersioningStore.DirectoryItem' from assembly 'EPiServer, Version=5.1.422.256, Culture=neutral, PublicKeyToken=8fe83dea738b45b7'.
at EPiServer.Migration.ObjectStoreCommon.ItemFields.get_Item()
at EPiServer.Migration.ObjectStoreHandler.Update(MigrationContext ctx)
[2008-05-26 20:59:54][Error] Migration terminated with error:
[2008-05-26 20:59:54][Error] System.TypeLoadException: Could not load type
at EPiServer.Migration.MigrationWorkflow.UpdateObjectStore(Object sender, EventArgs
at System.Workflow.ComponentModel.Activity.RaiseEvent(DependencyProperty
ependencyEvent, Object sender, EventArgs e)
at EPiServer.Migration.MigrationStepActivity.ExecuteHandler(Object sender, EventArgs
at System.Workflow.ComponentModel.Activity.RaiseEvent(DependencyProperty dependencyEvent, Object sender, EventArgs e)
at System.Workflow.Activities.CodeActivity.Execute(ActivityExecutionContext executionContext)
at System.Workflow.ComponentModel.ActivityExecutor`1.Execute(T activity, ActivityExecutionContext executionContext)
at System.Workflow.ComponentModel.ActivityExecutor`1.Execute(Activity activity, ActivityExecutionContext executionContext)
at System.Workflow.ComponentModel.ActivityExecutorOperation.Run(IWorkflowCoreRuntime workflowCoreRuntime)
at System.Workflow.Runtime.Scheduler.Run()
#20309
May 26, 2008 21:28
Did you found any solution to you problem becouse a get the same problem when a run the migrating tool.
/Per
2008-06-30 11:07:38][Information] 12,64 % completed, 61901(489611)
[2008-06-30 11:07:38][Error] An error occurred migrating data in Object Store. The exception was:
System.TypeLoadException: Det gick inte att läsa in typen EPiServer.FileSystem.Handler.VersioningStore.DirectoryItem från sammansättningen EPiServer, Version=5.1.422.256, Culture=neutral, PublicKeyToken=8fe83dea738b45b7.
   vid EPiServer.Migration.ObjectStoreCommon.ItemFields.get_Item()
   vid EPiServer.Migration.ObjectStoreHandler.Update(MigrationContext ctx)
[2008-06-30 11:07:39][Error] Migration terminated with error:
[2008-06-30 11:07:39][Error] System.TypeLoadException: Det gick inte att läsa in typen EPiServer.FileSystem.Handler.VersioningStore.DirectoryItem från sammansättningen EPiServer, Version=5.1.422.256, Culture=neutral, PublicKeyToken=8fe83dea738b45b7.
   vid EPiServer.Migration.MigrationWorkflow.UpdateObjectStore(Object sender, EventArgs e)
   vid System.Workflow.ComponentModel.Activity.RaiseEvent(DependencyProperty dependencyEvent, Object sender, EventArgs e)
   vid EPiServer.Migration.MigrationStepActivity.ExecuteHandler(Object sender, EventArgs e)
   vid System.Workflow.Activities.CodeActivity.Execute(ActivityExecutionContext executionContext)
   vid System.Workflow.ComponentModel.ActivityExecutor`1.Execute(T activity, ActivityExecutionContext executionContext)
   vid System.Workflow.ComponentModel.ActivityExecutor`1.Execute(Activity activity, ActivityExecutionContext executionContext)
   vid System.Workflow.ComponentModel.ActivityExecutorOperation.Run(IWorkflowCoreRuntime workflowCoreRuntime)
   vid System.Workflow.Runtime.Scheduler.Run()
#21495
Jun 30, 2008 11:27
