Archive overrides permission to publish
On our Epi 4.61 webb I found out that you can, regardless of your permissions at the target page, set a page to be archived to it. This gets the effect that you can use the funktion for archiving to work around your permission settings so that anyone now can publish anywhare. In our case I found a newspage that belonged way down in the structure showing up in our rootstructure. The person responsible for the page had manually tried to set the page to be archived to the trash, but missed the last klick in the structure, hence the page was published under our start page. Have we missed some setting in the admin mode or is this the way it is supposed to work?
#17785
Mar 07, 2008 15:15
