Problem with default document and System.Web.HttpContext.RewritePath
Hi, I have a server with two installations of EPiServer - 4.51 and 5.1. Every thing works fine with one exception. When trying to get the defult document (startpage) for the 5.1 intstallation i get a "NullReferenceException" www.mysite.net/sv <- works www.mysite.net en><- works www.mysite.net default.aspx><- works www.mysite.net><- does not work and - yes - ive checked default document settings in iis. this is the error i get: stack trace: nullreferenceexception: object reference not set to an instance of an object. system.web.httpcontext.rewritepathvirtualpath filepath virtualpath pathinfo string querystring boolean setclientfilepath 40 system.web.httpcontext.rewritepathstring filepath string pathinfo string querystring boolean setclientfilepath 51 episerver.web.urlrewritemodulebase.beginrequesteventhandlerobject sender eventargs e 585 system.web.synceventexecutionstep.system.web.httpapplication.iexecutionstep.execute 92 system.web.httpapplication.executestepiexecutionstep step boolean completedsynchronously 64 any ideas>
#17780
Feb 28, 2008 15:03
.Net Framework 2.0 SP1 solves the problem http://www.episerver.com/en/EPiServer_Knowledge_Center/FAQ_EPiServer_4/Hotfixes-and-known-issues/Getting-Object-reference-not-set-to-an-instance-of-an-object-in-site-root/
#18595
Mar 14, 2008 14:32
