Cannot delete unused language codes
A customer has asked us to remove the 'Language Encoding' field from the Advanced tab in Edit mode. I couldn't see an easy way to do this, so I thought I would remove all language codes except the required one. However, in Admin mode, when I click the 'Delete' button for a language in 'Edit Language Codes' and confirm the deletion I get the following error: The DELETE statement conflicted with the REFERENCE constraint "FK_tblLanguageBranch_tblLanguage". The conflict occurred in database "dbPulseConnect", table "dbo.tblLanguageBranch", column 'fkBranchLanguageID'. The statement has been terminated The Site is running on EPiServer 4.62B, and Globalization is disabled. Can I remove the language codes by 'hacking' the database, or for this particular requirement, is there a way to hide the 'Language Encoding' field from editors?
#17779
Feb 22, 2008 15:31
