user forced to login
i have some users that are prompted to login when accessing the startpage of our intranet, when they login with thier AD-credentials it works fine, but they have to login the next time as well. we have about 700 users, and this happens only to these three. any hints?
#17762
Jan 07, 2008 12:07
If you're using forms auth, could it be cookie settings? Not allowing the cookie to be stored would require a new login. /Steve
#18576
Jan 13, 2008 19:51
We have this problem too, sometimes our users get prompted for credentials. If you just restart IE and try to access the intranet-page again it often works. So this problem doesn't happen all the time, often it takes a long time before the user gets prompted for credentials the intranet site just loads and loads. Like if it times out and then the prompt appears.
#18577
Mar 25, 2008 13:08
