Object reference not set to an instance of an object.
Exception Details: System.NullReferenceException: Object reference not set to an instance of an object.
Source Error:
Line 28:
Line 29: :
Line 30: ]]>
Line 31:
Line 32:
Source File: d:\Inetpub\Konturen Online\Util\FileManager\ViewFile.ascx Line: 30
Stack Trace:
EPiServer.Util.FileManager.ViewFile.get_CreatedString() +20
ASP.util_filemanager_viewfile_ascx.__Render__control10(HtmlTextWriter __w, Control parameterContainer) in d:\Inetpub\Konturen Online\Util\FileManager\ViewFile.ascx:30
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +2065835
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +24
System.Web.UI.WebControls.TableCell.RenderContents(HtmlTextWriter writer) +97
System.Web.UI.WebControls.WebControl.Render(HtmlTextWriter writer) +29
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +25
System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +121
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +22
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +130
System.Web.UI.WebControls.WebControl.RenderContents(HtmlTextWriter writer) +7
System.Web.UI.WebControls.Table.RenderContents(HtmlTextWriter writer) +605
System.Web.UI.Control.Render(HtmlTextWriter writer) +7
System.Web.UI.HtmlControls.HtmlContainerControl.Render(HtmlTextWriter writer) +29
System.Web.UI.HtmlControls.HtmlTableRow.RenderChildren(HtmlTextWriter writer) +45
System.Web.UI.HtmlControls.HtmlTable.RenderChildren(HtmlTextWriter writer) +45
ASP.secure_edit_filemanagementcontrol_ascx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in c:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\Temporary ASP.NET Files\root\40facc8c\9ac6a812\App_Web_jtm5b9og.11.cs:0
System.Web.UI.HtmlControls.HtmlForm.RenderChildren(HtmlTextWriter writer) +59
System.Web.UI.HtmlControls.HtmlForm.Render(HtmlTextWriter output) +68
System.Web.UI.HtmlControls.HtmlForm.RenderControl(HtmlTextWriter writer) +37
ASP.secure_edit_actionwindow_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) in d:\Inetpub\Konturen Online\secure\edit\ActionWindow.aspx:14
System.Web.UI.Page.Render(HtmlTextWriter writer) +26
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1896
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL: 1. Add a "Debug=true" directive at the top of the file that generated the error. Example: <%@ page language="C#" debug="true"> or: 2) Add the following section to the configuration file of your application:
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
%@>/Fredrik
