FK_tblWorkPage_tblSID
After having installed EPiServer 4.61 - Hotfix 5, I get an SQL exception when trying to publish articles of any kind. The error message is: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_tblWorkPage_tblSID". The conflict occurred in database "[database name]", table "dbo.tblSID", column 'pkID'. I've followed the steps in the readme.txt when installing the hotfix. How do I solve this? /Kristoffer
#17697
Sep 13, 2007 12:47
The error message above is displayed if I try to publish an update to an article. If I try to pulish a new article, the error messase is slightly different: The INSERT statement conflicted with the FOREIGN KEY constraint "FK_tblPage_tblSID1". The conflict occurred in database "[database name]", table "dbo.tblSID", column 'pkID'.
#18539
Sep 13, 2007 12:57
This issue seems to be caused by some StarCommunity(?) entris in web.config. Deleting the entries below solved the problem.
#18540
Sep 14, 2007 9:05
