Export XForms to Excel
Hello I have a problem on a site. I´m trying to export a XForm to Excel. It works fine execept for some fields. In the form we have a textfield where the customer should put her creditcard number. If they write for exemple 1234123412341234, EPiServer saves the correct value in the database. But when i tries to export to Excel i get 1234123412341230. The last number becomes "0". This happens only if there are more than 15 numbers. What is wrong, is it the export function that dosen´t work correct or is it Excel that handels this wrong? Is there any workaround or solution for this? We are using EPiServer 4.50.5.176 /Emil
#17677
Jul 11, 2007 9:00
The problem is that Excel treats the cardnumber as a large integer, and as such it suffers from "The 15 significant digit limitation". You'd get the same behaviour if you enter 1234123412341234 in a cell and hit enter. More on this limitation can be found in this thread: http://groups.google.se/group/microsoft.public.excel.misc/browse_thread/thread/ddb7f26b246a66a5/de70bf58b8b7ff9f?lnk=st&q=%22The+15+Significant+Digit+Limitation%22&rnum=1&hl=sv#de70bf58b8b7ff9f The solution would be to get Excel to treat the number as a textstring instead, possibly by prepending the number with an apostroph ' This would require you to add some code upon formsubmit to take care of this prepending, check out the event 'BeforeSubmitPostedDataEvent' for the XFormControl. Regards, Johan Olofsson EPiServer AB
#18520
Jul 11, 2007 9:55
