Object reference not set to an instance of an object
When i try to install EpiServer i get this errormessage at the end of the installation: Running assembly installer for /bin/MILHTMLParser.dll Object reference not set to an instance of an object.
#17665
Jun 19, 2007 14:25
Hi. Make sure you have upgraded to the latest EPiServer Manager, current version is 1.3.2. Regards Per EPiServer Support
#18501
Jun 19, 2007 16:39
When i try to download the newest version or go to EpiManager Online I get an error page : "Access denied You do not have sufficient rights to view this page. If you have found anything that doesn’t work, let us know so we can correct the error that may be causing the problem (don’t forget to describe what you did to generate the error). "
#18502
Jun 20, 2007 8:12
Hi. You need to be registered and login to the knowledge center to get access. http://www.episerver.com/en/EPiServer_Knowledge_Center/ Regards Per
#18503
Jun 20, 2007 17:03
