File management in EPiServer 5.0 not working
I can drag and drop files into root directory of Global, Document and Page Files folders. But if I create a subfolder, I'm not able to drag and drop. Why is that?
#17741
Nov 14, 2007 16:20
To answer my own problem (Since no one at EPiServer does it) The prolem is that when you create a new folder, there are no files there and you will not be able to drag and drop files. After I uploaded a file the "standard" way, I can drag and drop fiels AS LONG as I drop it over the line that shows a file. If I try to drag and drop files below this line (into the empty space), it will not be possible. I hope this "bug" get fixed in a later version.
#18560
Nov 16, 2007 12:41
do you know how delete a document in the filemanagerbrowser,i can't delete it,right-click function can't use.do you know why is this?
#18561
Dec 06, 2007 8:14
I just mark the file by clicking it and then click the red X at the top of the file manger menu panel.
#18562
Dec 20, 2007 10:22
