Hi.
Running 5.2.375.7 an are getting
System.Web.Services.Protocols.SoapException: Exception of type 'NetworkedPlanet.TMService.TMServiceException' was thrown. ---> NetworkedPlanet.TMService.TMServiceException: Exception of type 'NetworkedPlanet.TMService.TMServiceException' was thrown.
at NetworkedPlanet.TMService.TMServiceImpl.SafeGetTopicMap(String topicMapName)
at NetworkedPlanet.TMService.TMServiceImpl.ProcessTransaction(String topicmap, XmlDocument txn)
at NetworkedPlanet.TMService.TMService.ProcessTransaction(String topicmap, XmlDocument tmfragment) - System.Xml.XmlDocument
Beskrivelse: Det oppstod et ubehandlet unntak under kjøring av gjeldende webforespørsel. Gå gjennom stakksporingen hvis du vil ha mer informasjon om feilen og hvor den oppstod i koden.
Unntaksdetaljer: System.Web.Services.Protocols.SoapException: System.Web.Services.Protocols.SoapException: Exception of type 'NetworkedPlanet.TMService.TMServiceException' was thrown. ---> NetworkedPlanet.TMService.TMServiceException: Exception of type 'NetworkedPlanet.TMService.TMServiceException' was thrown.
Kildefeil:
Et ubehandlet unntak ble generert i løpet av utførelsen av gjeldende webforespørsel. Informasjon om opprinnelse og plassering for unntaket kan hentes ved hjelp av stakksporingen for unntak nedenfor.
Stakksporing:
[SoapException: System.Web.Services.Protocols.SoapException: Exception of type 'NetworkedPlanet.TMService.TMServiceException' was thrown. ---> NetworkedPlanet.TMService.TMServiceException: Exception of type 'NetworkedPlanet.TMService.TMServiceException' was thrown.
at NetworkedPlanet.TMService.TMService.ProcessTransaction(String topicmap, XmlDocument tmfragment)]
System.Web.Services.Protocols.SoapHttpClientProtocol.ReadResponse(SoapClientMessage message, WebResponse response, Stream responseStream, Boolean asyncCall) +431766
System.Web.Services.Protocols.SoapHttpClientProtocol.Invoke(String methodName, Object[] parameters) +204
NetworkedPlanet.WebServiceClient.TMService.ProcessTransaction(String topicmap, XmlNode tmfragment) +65
NetworkedPlanet.EPiServerModule.EPiTMServiceHelper.ProcessTransaction(TopicMapTransaction txn) +383
NetworkedPlanet.EPiServerModule.EPiTMServiceHelper.CreateTopic(String subjectIdentifier, String name, String topicTypeSubjectIdentifier) +180
NetworkedPlanet.EPiServerModule.EPiTMServiceHelper.EnsureTopic(String subjectIdentifier, String name, String topicTypeSubjectIdentifier) +315
NetworkedPlanet.EPiServerModule.EPiConfig.get_NP_TM_PageIdOccurrenceTypeId() +48
NetworkedPlanet.EPiServerModule.IdentityHelper.GetTopicIdsByPageIds(IEnumerable`1 pageIdList) +194
NetworkedPlanet.EPiServerModule.PageHierarchyCopyUtility.CreateTopicHierarchyForCopiedPages(PageData sourcePage, PageData copiedPage, CopyPageEventArgs copyArgs) +46
NetworkedPlanet.EPiServerModule.TopicMapEventHandler.EPDataFactory_CreatedPage(Object sender, PageEventArgs e) +369
EPiServer.PageEventHandler.Invoke(Object sender, PageEventArgs e) +0
EPiServer.Core.PageStoreBase.RaisePageEvent(Object key, PageEventArgs eventArgs) +76
EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, AccessLevel requiredSourceAccess, AccessLevel requiredDestinationAccess, Boolean publishOnDestination, Boolean allowThreading) +363
EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, Boolean allowThreading) +76
EPiServer.UI.Edit.CommandActions.PasteCommandTool_Click(Object sender, EventArgs e) +714
EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +107
EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +135
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +13
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +175
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1565
This when try to copy n paste a page when logged in Edit Mode.
Serverfeil i programmet /. -------------------------------------------------------------------------------- Can't copy page, because: "10/30/2007 12:25:00" er en ugyldig verdi for "Begynn publisering". Beskrivelse: Det oppstod et ubehandlet unntak under kjøring av gjeldende webforespørsel. Gå gjennom stakksporingen hvis du vil ha mer informasjon om feilen og hvor den oppstod i koden. Unntaksdetaljer: EPiServer.Core.EPiServerException: Can't copy page, because: "10/30/2007 12:25:00" er en ugyldig verdi for "Begynn publisering". Kildefeil: Et ubehandlet unntak ble generert i løpet av utførelsen av gjeldende webforespørsel. Informasjon om opprinnelse og plassering for unntaket kan hentes ved hjelp av stakksporingen for unntak nedenfor. Stakksporing: [EPiServerException: Can't copy page, because: "10/30/2007 12:25:00" er en ugyldig verdi for "Begynn publisering".] EPiServer.LocalPageStore.Copy(PageReference pageLink, PageReference destinationLink, AccessLevel requiredSourceAccess, AccessLevel requiredDestinationAccess, Boolean publishOnDestination, Boolean allowThreading) +651 EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, AccessLevel requiredSourceAccess, AccessLevel requiredDestinationAccess, Boolean publishOnDestination, Boolean allowThreading) +266 EPiServer.DataFactory.Copy(PageReference pageLink, PageReference destinationLink, Boolean allowThreading) +108 EPiServer.UI.Edit.CommandActions.PasteCommandTool_Click(Object sender, EventArgs e) +985 EPiServer.UI.WebControls.ToolButton.OnClick(EventArgs e) +101 EPiServer.UI.WebControls.ToolButton.RaisePostBackEvent(String eventArgument) +132 System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +11 System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +174 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +5102 -------------------------------------------------------------------------------- Versjonsinformasjon: Microsoft .NET Framework versjon:2.0.50727.832; ASP.NET versjon:2.0.50727.832
