Error validating license: Not found
I get the following exception in my local developing environment: System.Management.ManagementException: Not found And when I try to do an update from EpiServer Manager I get: Error validating license: Not found When I remove the license (just for test) and try to update again I get: Error validating license: The license file "C:\Inetpub\Homepage-dev-local\License.config" does not exist (Check your license file) I have checked that my license is stil valid. Any suggestions on what could be wrong? /Eva
#17715
Oct 08, 2007 16:56
Hi, Maybe you have solved your problem by now. If not, do you have a stacktrace of the error? It could (has been before) problem with Your WMI-provider. Which we use to verify your license file. If so, see http://www.microsoft.com/downloads/details.aspx?familyid=d7ba3cd6-18d1-4d05-b11e-4c64192ae97d&displaylang=en And the following article: http://msdn2.microsoft.com/en-us/library/aa394603.aspx
#18549
Oct 30, 2007 17:10
