Mirroring job fails: "Item has already been added"
Hi, We use some 30 channels for mirroring which is set up to run scheduled every 10 minutes. Some of the channel jobs results in an error with status text 'Item has already been added. Key in dictionary: "1" Key being added: "1"' Any idea what is wrong? I do not get any help from technical documents. Regards Thomas Jansson
#17602
Jan 24, 2007 15:21
I had the same problem. You get this error/warning if the page already has been mirrored. This will halt the mirror process, but if you rerun the job it will probebly work ok. I would guess that in youre case there is one or more pages that are beeing updated in diffrent channels. Regards
#18449
Apr 10, 2007 11:58
