SDK API docs describe default LanguageBranch method/property, but doesn't exist
Hi, I'm compiling code against EPiServer.dll vewrsion 4.60.0.165 on Windows XP SP2. According to the SDK API docs there should be, introduced in 4.60.0.87, in the EPiServer.DataAbstraction.LanguageBranch class: public static LanguageBranch LoadDefault() and bool isDefault However, I cannot find these in the DLL (using VS2003 Intellisense). This is also what I'm using to find the version of the EPiServer DLL that I'm referencing: under Project References -> EPiServer -> Properties window -> Version attribute. Can someone explain this to me please? If these are not present, I'm hoping that this is a valid way to determine the default language, could someone confirm this for me please? private bool IsDefaultLanguage(string languageID) { LanguageBranchCollection languages = LanguageBranch.List(true); string defaultLanguage = System.Configuration.ConfigurationSettings.AppSettings["EPsDefaultLanguageBranch"]; return (defaultLanguage == null ? true : defaultLanguage.Equals(languageID)); } Many thanks, Andy
#17589
Dec 06, 2006 14:49
