Problems with Documents in 4.50
Hi, I have some trouble with the document system (with versioning) in version 4.50. It works fine to upload the document-files and if I check them on the server the files are OK. But when I add a link to a document in EPiServer and try to view it in the browser, the document is corrupted. I have tried pdf, doc and txt files. pdf and doc files have this behaviour but txt files works fine. Do you have any idea what is causing this? thanks /Tobias
#17432
Aug 22, 2005 15:45
Could this be a problem with a browser plug-in? Have you tried to right click and Save As to disk, and open the document from there?
#18195
Aug 23, 2005 15:45
Thanks for the reply. I found that the EP already know about the problem http://www.episerver.com/templates/page____3802.aspx
#18196
Aug 23, 2005 16:41
