Root context
Hi. After importing groups from our Active Directory (AD), I experienced problems logging on. Before entering the Admin mode, I sat the root context 3 levels down from the root in the organizational structure, for example "Level3-Level2-Level1-root". In the import window, I now got the subset I wanted. However, I was unable to log on. I had to remove the sublevels from the root context. Is this because the user I'm trying to log in with, is higher in the organizational structure than Level3, or is it something wrong in EPiServer? (After removing the sublevels, leaving the root context in web.config to "root", I successfully logged in.) Thanks, Frank :)
#17281
Jun 29, 2004 18:06
