DOP edit: 'Save' option doesn't work!?
I'm loged inn, and from the browser I right click the text area. The edit menue shows up and I choose 'Edit'. After editing the text, I right click again and choose the 'Save' option. NOTHING HAPPENS!? Other options in same menue works fine. Any idea? BR., Alireza
#17248
Jan 22, 2004 14:20
If you are using .NET framework 1.1 it might be that you have not installed the hotfix for postbacks. More information about this can be found at http://www.episerver.com/faq
#17859
Feb 13, 2004 12:12
