Custom editor for PromotionData Description property
Is it possible to switch the editor for PromotionData.Description to a custom one instead of "textarea"?
I have tried this to see if I can modify the metadata, but no success.
[InitializableModule]
[ModuleDependency(typeof(InitializableModule))]
public class PromotionDataMetaDataExtenderInitialization : IInitializableModule
        var registry = context.Locate.Advanced.GetInstance<MetadataHandlerRegistry>();
        registry.RegisterMetadataHandler(typeof(PromotionData), new PromotionDataMetaDataExtender());
    public void Preload(string[] parameters) { }
    public void Uninitialize(InitializationEngine context) { }
public class PromotionDataMetaDataExtender : IMetadataExtender
    public void ModifyMetadata(ExtendedMetadata metadata, IEnumerable<Attribute> attributes)
        foreach (var metadataProperty in metadata.Properties)
            if (metadataProperty.PropertyName == nameof(PromotionData.Description))
                metadataProperty.ShowForEdit = false; // Try and hide to see if the extender has had an effect
Decompiled PromotionData class
namespace EPiServer.Commerce.Marketing
    // Represents a content based promotion item.
    [AvailableContentTypes(Availability.None)]
    [AdministrationSettings(CodeOnly = true, GroupName = "marketing")]
    [CLSCompliant(false)]
    public abstract class PromotionData : BasicContent
        // Gets or sets the description of the promotion.
        [UIHint("textarea")]
        [Display(Order = 10, GroupName = "EPiServerCMS_SettingsPanel", Prompt = "/commerce/properties/description/prompt")]
        public virtual string Description { get; set; }
#337850
Edited, Apr 16, 2025 9:41
Found a way by implementing a custom IMetaDataProvider
Seems to work fine.
 public class CustomEpiserverMetadataProvider : IMetadataProvider
     private IMetadataProvider _defaultMetadataProvider;
     public CustomEpiserverMetadataProvider (IMetadataProvider metadataProvider)
         _defaultMetadataProvider = metadataProvider;
     public ExtendedMetadata CreateMetadata(IEnumerable attributes, Type containerType, Func<object> modelAccessor, Type modelType, string propertyName)
         return _defaultMetadataProvider.CreateMetadata(attributes, containerType, modelAccessor, modelType, propertyName);
     public IEnumerable GetMetadataForProperties(object container, Type containerType)
         var metadataForProperties = _defaultMetadataProvider.GetMetadataForProperties(container, containerType).ToList();
         if (container is PromotionData)
             foreach (var propertyMetadata in metadataForProperties)
                 if (propertyMetadata.PropertyName == nameof(PromotionData.Description))
                     propertyMetadata.UIHint = "my-custom-ui-hint"; // Replace the default UIHint "textarea" with our custom editor
         return metadataForProperties;
Registering it using a InitializationModule
  public class CustomEpiserverMetadataProviderRegistration : IInitializableModule
          var registry = context.Locate.Advanced.GetInstance();
          var metadataHandlers = registry.GetMetadataHandlers(typeof(ContentData));
          IMetadataProvider defaultMetadataProvider = (IMetadataProvider)metadataHandlers.FirstOrDefault(i => i is IMetadataProvider);
          registry.RegisterMetadataHandler(typeof(ContentData),new CustomEpiserverMetadataProvider(defaultMetadataProvider));
#337868
Edited, Apr 17, 2025 8:02
