Take a look into what AddCmsAspNetIdentity() does. It might already do some of the stuff you do above which causes some type of conflict.
Also compare with the Startup.cs in an Alloy site.
This issue got fixed, as i noticed that there were still few refrences of Framework nuget packages. Once they were removed properly and compile error fixed. Applciation starts working properly in DXP.
I am migrating my .net framework application from version 11 to 12, the application is working fine in my localhost. But when i deployed the same in DXP Intergation environement(https://intecore.connectinvest.com/ ref URL) getting below error message when i am trying to login.
Refer below error logs:
2025-02-20T12:54:22.174279598Z fail: Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware[1]
2025-02-20T12:54:22.174308284Z An unhandled exception has occurred while executing the request.
2025-02-20T12:54:22.174313332Z System.InvalidOperationException: Headers are read-only, response has already started.
2025-02-20T12:54:22.174317522Z at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpHeaders.ThrowHeadersReadOnlyException()
2025-02-20T12:54:22.174321486Z at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpResponseHeaders.Microsoft.AspNetCore.Http.IHeaderDictionary.set_SetCookie(StringValues value)
2025-02-20T12:54:22.174325802Z at Microsoft.AspNetCore.Http.ResponseCookies.Append(String key, String value, CookieOptions options)
2025-02-20T12:54:22.174329533Z at Microsoft.AspNetCore.CookiePolicy.ResponseCookiesWrapper.Append(String key, String value, CookieOptions options)
2025-02-20T12:54:22.174333473Z at EPiServer.Framework.DependencyInjection.Internal.VisitorGroupResourceFilter.OnResourceExecutionAsync(ResourceExecutingContext context, ResourceExecutionDelegate next)
2025-02-20T12:54:22.174337780Z at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
2025-02-20T12:54:22.174342504Z at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeNextResourceFilter()
2025-02-20T12:54:22.174346614Z --- End of stack trace from previous location ---
2025-02-20T12:54:22.174350029Z at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Rethrow(ResourceExecutedContextSealed context)
2025-02-20T12:54:22.174353530Z at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.Next(State& next, Scope& scope, Object& state, Boolean& isCompleted)
2025-02-20T12:54:22.174357183Z at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.InvokeFilterPipelineAsync()
2025-02-20T12:54:22.174360657Z --- End of stack trace from previous location ---
2025-02-20T12:54:22.174363902Z at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
2025-02-20T12:54:22.174367523Z at Microsoft.AspNetCore.Mvc.Infrastructure.ResourceInvoker.<InvokeAsync>g__Awaited|17_0(ResourceInvoker invoker, Task task, IDisposable scope)
2025-02-20T12:54:22.174372620Z at Microsoft.AspNetCore.Routing.EndpointMiddleware.<Invoke>g__AwaitRequestTask|6_0(Endpoint endpoint, Task requestTask, ILogger logger)
2025-02-20T12:54:22.174376594Z at UnknownActionMiddleware.InvokeAsync(HttpContext context) in C:\Tools\ConnectInvest\ConnectInvestWeb\ConnectInvest.Core.Shared\UnknownActionMiddleware.cs:line 28
2025-02-20T12:54:22.174398097Z at Microsoft.AspNetCore.Session.SessionMiddleware.Invoke(HttpContext context)
2025-02-20T12:54:22.174401734Z at Microsoft.AspNetCore.Session.SessionMiddleware.Invoke(HttpContext context)
2025-02-20T12:54:22.174405403Z at Microsoft.AspNetCore.Authorization.AuthorizationMiddleware.Invoke(HttpContext context)
2025-02-20T12:54:22.174408882Z at Microsoft.AspNetCore.Authentication.AuthenticationMiddleware.Invoke(HttpContext context)
2025-02-20T12:54:22.174412937Z at Microsoft.AspNetCore.Diagnostics.ExceptionHandlerMiddleware.<Invoke>g__Awaited|6_0(ExceptionHandlerMiddleware middleware, HttpContext context, Task task)
2025-02-20T12:54:22.177504246Z fail: Microsoft.AspNetCore.Server.Kestrel[13]
2025-02-20T12:54:22.177528180Z Connection id "0HNAHIIUQ23IE", Request id "0HNAHIIUQ23IE:00000009": An unhandled exception was thrown by the application.
2025-02-20T12:54:22.177533596Z System.InvalidOperationException: Headers are read-only, response has already started.
2025-02-20T12:54:22.177537936Z at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpHeaders.ThrowHeadersReadOnlyException()
2025-02-20T12:54:22.177542456Z at Microsoft.AspNetCore.Server.Kestrel.Core.Internal.Http.HttpResponseHeaders.Microsoft.AspNetCore.Http.IHeaderDictionary.set_SetCookie(StringValues value)
And, below is my Startup configuration for Indentity:
// Configure cookie authentication
services.AddAuthentication(options =>
options.DefaultAuthenticateScheme = CookieAuthenticationDefaults.AuthenticationScheme;
options.DefaultSignInScheme = CookieAuthenticationDefaults.AuthenticationScheme;
options.DefaultChallengeScheme = CookieAuthenticationDefaults.AuthenticationScheme;
.AddCookie(options =>
options.LoginPath = new PathString("/UserAccount/Login");
options.LogoutPath = new PathString("/UserAccount/LogOff");
options.Cookie.HttpOnly = true;
options.Cookie.SecurePolicy = CookieSecurePolicy.Always; // Ensure cookies are only sent over HTTPS
options.ExpireTimeSpan = TimeSpan.FromHours(5); // Use your 'rememberMePeriod' here
options.SlidingExpiration = false;
// Identity validation (security stamp validation every 5 minutes)
options.Events = new CookieAuthenticationEvents
OnValidatePrincipal = SecurityStampValidator.ValidatePrincipalAsync
// Add authorization policies if needed
services.AddAuthorization(options =>
options.AddPolicy("CmsAccess", policy =>
policy.RequireRole("CmsAdmins", "CmsEditors", "WebAdmins", "WebEditors")); // Required roles for accessing CMS
services
.AddCmsAspNetIdentity<ApplicationUser>()
.AddCms()
.AddFind()
.AddEmbeddedLocalization<Startup>();
// Ensure correct registration of ApplicationDbContext for Optimizely Identity
services.AddDbContext<ApplicationDbContext<ApplicationUser>>(options =>
options.UseSqlServer(Configuration.GetConnectionString("EPiServerDB"))); // Ensure your connection string is correct
Please suggest where i am missing.
Many thanks.
