You can do that by modifying your TinyMCE configuration in Startup.cs
Here is an example code:
services.Configure<TinyMceConfiguration>(config =>
config.InheritSettingsFromAncestor = true;
config.Default()
.Toolbar("styles | bold italic underline | epi-link anchor | image epi-image-editor epi-personalized-content | bullist numlist outdent indent | epi-dnd-processor | removeformat | fullscreen code")
.StyleFormats(
new
title = "Wrap Image",
block = "span",
selector = "img",
classes = "image-wrapper",
styles = new
display = "inline-block",
border = "2px solid red",
padding = "5px"
I am not sure what I missed earlier but I couldn't get this to work so I went the hard route of creating an external plugin for this issue. However trying your example also seems to work. I will go ahead and replace my external plugin code with this. Thank you.
Is there a way to add a span wrapper with style attributes and classes for an image selector using TinyMce Configurations. I want to be able to select and image and wrap it in a span element.
