Hi, you're creating a policy called AllowSpecificOrigin, but where and how are you using it?
I just pasted following in the browser console, and it doesn't download the images reliably. It just downloads the first image for me. Checking the network tab, I can see that both images are requested and the server is responding with correct CORS headers. This way of downloading documents is just not reliable.
const files = [
url: "https://fastly.picsum.photos/id/173/200/300.jpg?hmac=9Ed5HxHOL3tFCOiW6UHx6a3hVksxDWc7L7p_WzN9N9Q",
url: "https://fastly.picsum.photos/id/1005/200/400.jpg?hmac=qFOCeB6Gj87mocLz5LEGRxB1R2sbbzgexrjTuF_wrpc",
const fetchPromises = files.map((file) =>
fetch(file.url)
.then((response) => {
if (!response.ok) {
throw new Error(`Failed to fetch ${file.name} from ${file.url}`);
return response.blob();
.then((blob) => {
const url = URL.createObjectURL(blob);
const link = document.createElement("a");
link.href = url;
link.download = `${file.name}.jpg`;
link.click();
console.log(`${file.name} downloaded successfully`);
.catch((error) => console.error(`Error downloading ${file.name}:`, error))
await Promise.all(fetchPromises);
It's not the fetch that fails with above code, but rather the "hack" with a download link.
I am currently working on a React application that uses the Fetch API to retrieve documents from Episerver. However, we’re encountering CORS errors. I faced a similar issue with CMS 11, where I attempted several approaches to handle the issue, which I’ve detailed in another post
In CMS 12, CORS is built-in, but we are still experiencing CORS errors. It works in CMS 12 but the behavior is inconsistent compared to CMS 11, where the issue was constant.
My CMS 12 code snippet for CORS configuration is as follows:
The _configuration["AllowedOrigins"] includes the sites calling Optimizely, defined in the appsettings from Passportal:
"AllowedOrigins": https://xyz-dev.xxx.com, https://uat.xxx.com
Note: I have also tried wild card character to see if that works but the issue is still inconsistent wherein the documents fetching works at 1 time & stops the next instance.
When I temporarily enable CORS at the WebApp level via the Azure Portal, the application works both in CMS 11 & 12. But when I attempt to implement CORS via code changes, the issue persists. It seems something might be cutting off the headers at the Cloudflare level or another point, but I can’t pinpoint it.
The challenge with this workaround is that I only have access to the lower environments, and while I can make the change there, Optimizely manages the production and business testing environments. They are not willing to implement this change, which brings me to their response:
Optimizely’s Response: "CORS is not a feature that can be configured on the DXP platform. This was a decision made by the product team, and the configurations must be done within the code base."
So reaching out to Optimizely support has not been helpful, as we're just going in circles without a resolution. We implemented an alternate solution in CMS 11, but we'd like to see CORS functionality work smoothly in CMS 12, given that it’s built-in.
Has anyone here encountered similar issues or have suggestions on how to resolve this in CMS12?
Any help would be greatly appreciated, as Optimizely support hasn’t been effective so far.
My client side script code :
Regards,
Farhin
