Auto Translation Disable for specific page
We have a requirement to disable Auto-Translate from language manager on specific page only.
Can anyone suggest how we can achieve this?
I am trying but still draft version is creating.
Deepmala Sharma
#341251
Dec 11, 2025 10:22
Are you using the built-in provider you must disable the feature in the UI at the parent level. All children will be affected.
Translate content (new UI in 5.3.0)
Read more at https://docs.developers.optimizely.com/content-management-system/docs/optimizely-languages#configure-auto-translation
If you want a more granular approach you'll need to do some coding.
#341254
Dec 11, 2025 12:06
Ive looked at the plugin, and its really half done, not every thing is implemented the right way. I will report that.There is
"EPiServer": {
    "CmsUI": {
      "LanguageManager": {
        "RestrictedTypes": [
          "AlloySandbox.Models.Pages.*",
          "AlloyTemplates.Models.Pages.ExamplePage2"
But it is never used in the code! So the way is to override LanguageBranchManager.
You can exlude properties by overriding IEnumerable<string> ExcludedProperties => new string[2] { "CatalogContent.SeoUri", ".MetaTitle" };
But you need to override many methods in the ILanguageBranchManager because it is poorly build.
Still, i dont see you can disable the button, you can trigger the autotranslate but return false, you get a message "Error see the logs" which is not user friendly.
#341270
Dec 13, 2025 10:17
Hi Luc Gosso (MVP), Eric Herlitz,
Currently I am overriding ILanguageBranchManager with all methods. I am triggering autotranslation it is return false. Page is not translating throwing warning "Error occurs while translating content, please check the logs for more details."
As for now i did this implementation. But i was expecting this warning pop up massage also should not come. But i am unable to achieve this.
Deepmala
#341273
Edited, Dec 15, 2025 10:03
Hi Deepmala S
Thats the expected behaviour.
https://support.optimizely.com/hc/en-us/articles/33555909069069-Error-occurs-while-translating-content-please-check-the-logs-for-more-details
If you need to still disabled this popup, you can no-op success(Perform no operation and return success) at service level
Hope this helps.
#341315
Dec 19, 2025 13:18
